allgood customs Posted August 20, 2009 Report Share Posted August 20, 2009 So i watched a vid about what all the f700bt could do and i noticed his icons on the main screen were different (destination, contacts, AV source) If anyone knows how to change them could you please post an exact how to. This would be great Quote Link to post Share on other sites
copbait Posted August 20, 2009 Report Share Posted August 20, 2009 pics are located in apl/image.res after unziping image.res it is image/common. Make sure you repack everything EXACTLY as it was before you messed with it. I at first did not and had to redo it. For more info search guga version 2.0 Quote Link to post Share on other sites
copbait Posted August 22, 2009 Report Share Posted August 22, 2009 A couple things I forgot to mention that caused me problems, when you save your image in Photoshop make sure it is saved as a windows bmp file 240x240, and the bit depth 24. Hope this helps, if I was not clear enough repost or pm me. Quote Link to post Share on other sites
parruso Posted September 1, 2009 Report Share Posted September 1, 2009 Hello. Is it possible, in addition to change icons, change the functions? I mean, I do not use the handsfree, and instead of having "contacts" in the menu, I would like to access the iPod, or AV. Would it be possible to create a shortcut in the menu? Quote Link to post Share on other sites
