cococool Posted September 26, 2009 Report Share Posted September 26, 2009 I installed the whole eu 3.0 flash folder from scratch and everything is working again. Added several mods and everything still ok. Only after adding the hacked ezrider for 3d buildings the problem is back. So it has something to do with the hacked ezrider, are there different version of hacked ezrider 3d? Quote Link to post Share on other sites
mygalles Posted September 28, 2009 Report Share Posted September 28, 2009 hello cococool, I have the same probleme on my unit. I use for my update the 3.0003 from this post http://www.avic411.com/forum/viewtopic.php?f=34&t=26625 and after the upgrade from this post http://www.avic411.com/forum/viewtopic.php?f=34&t=27495, but no result ! Can you tell me what version have you use for your scratch install please ? thank Quote Link to post Share on other sites
cococool Posted September 28, 2009 Report Share Posted September 28, 2009 I used the 3.0003 as well, but deleted all files on the flash disk first. I do not use the hacked ezrider anymore and updated the bluetooth with the latest from pioneer. Quote Link to post Share on other sites
cococool Posted September 29, 2009 Report Share Posted September 29, 2009 Does anybody know if there's an updated, hacked, ezrider.exe that will work with bluetooth AND tmc, so that it's possible for european users to view the 3d buildings as well? Quote Link to post Share on other sites
mygalles Posted October 1, 2009 Report Share Posted October 1, 2009 thank so much cococool all is correct with 3.0003.... for the 3d building, I use the "original 3.0003" ezrider and it's OK... but it's not the latest map Quote Link to post Share on other sites
cococool Posted October 1, 2009 Report Share Posted October 1, 2009 Strange, I only get the landmarks, not the buildings with 30003... Quote Link to post Share on other sites
Sid the Sloth Posted October 7, 2009 Report Share Posted October 7, 2009 Hi cococool, I have had the same problem as you are having. Or bluetooth was working or TMC was working. Now everything is working fine , I did the following: I installed version 3.0 from this thread: http://www.avic411.com/forum/viewtopic.php?f=34&t=26625 thanks to Tomola!!! Then I installed the hacked ezrider which you can find anywhere in this forum. Installed the newest iGO 8.3 maps/buildings etc. I could find (Q2 2009) Installed newest version of IDT's hack (version 4.9) After this I still had the same problem, after reading IDT's instructions again, I found out that I skipped a crucial step, although IDT has clearly described this step (reading can be so difficult ) : deleting al files in the My Flash Disk\USER\UserData\iGo\save directory, everything should be deleted except for favourites.dat if you have it After carrying out this step, everything worked out fine!!! So thanks IDT!! I was an absolute fan of the GTIMatt mod (still think it's a great one, but it's not compatible with fw version 3.0) Now I'm using version 4.9 of your mod and I must admit it's pretty impressive, works great, has all the functions I need (I especially like the TMC button in the nav screen) so keep up the good work and thanks for all the effort, I know that a lot of people are really happy with your work Quote Link to post Share on other sites
mr_cs Posted October 7, 2009 Report Share Posted October 7, 2009 deleting al files in the My Flash Disk\USER\UserData\iGo\save directory, everything should be deleted except for favourites.dat if you have it Can anyone explain what the various files in the save folder actually do or are. My TMC is erratic but even if I have the files to restore I would like to know what I am losing if I delete as suggested here. Thanks Colin Quote Link to post Share on other sites
