Raggi73 Posted October 31, 2009 Report Share Posted October 31, 2009 Hi. I have a 900Bt brand new with V3.0xx software installed a week ago and everything works fine. Want to do a backup, but can't get the Testmode to work. I have tried Testmode_v2.3 etc, but I only get a Storagecard/TestMode/Copytool.exe error. Starting to think this unit is imune for this kind of workaround. My goal is 2 things: 1 - Copy MyFlashDisk for backup (I have the emulator installed and want to toy around) 2 - The nav-mute button is very important. Don't want to do much else at this point, but the two mentioned tasks. I live in Norway (if that has anything to do with it?) Attached two pictures from my SD card. Am I missing something? Quote Link to post Share on other sites
carver Posted November 1, 2009 Report Share Posted November 1, 2009 all working, so try format or change SD card. Quote Link to post Share on other sites
misterblue Posted November 1, 2009 Report Share Posted November 1, 2009 file MITACAP not required with testmode2.3 Quote Link to post Share on other sites
Raggi73 Posted November 1, 2009 Author Report Share Posted November 1, 2009 Damn it. Such a easy solution: I needed to format my SD card again using Dos: Format (drive): /fs:fat32 comand. Thought I should give it a last try today, and then I remembered something about formating it in Dos. I have formated it in Fat32 via WinXp using both Quick and std format, but with the same result. Now I have a backup of MyFlashDrive. Will start working on the Nav-Mute button fuction. Also a splash screen and a different sound when I'm getting close to a speed camer. Anyone have this allready? Quote Link to post Share on other sites
ill.die.trying Posted November 1, 2009 Report Share Posted November 1, 2009 Damn it. Such a easy solution: I needed to format my SD card again using Dos: Format (drive): /fs:fat32 comand.Thought I should give it a last try today, and then I remembered something about formating it in Dos. I have formated it in Fat32 via WinXp using both Quick and std format, but with the same result. Now I have a backup of MyFlashDrive. Will start working on the Nav-Mute button fuction. Also a splash screen and a different sound when I'm getting close to a speed camer. Anyone have this allready? there's a bunch of modded data.zip in the forum and it just all comes down to personal preference Quote Link to post Share on other sites
