garciarios Posted November 5, 2009 Report Share Posted November 5, 2009 I am replacing my F90BT with the Z110BT. I installed the F90BT myself so I am sure I can do the install. I am installing the MSN Direct, Ipod and the SWI-PS with the PAC SWI-PS I am totally lost. Is there a tutorial to install it with pictures? I have a 2004 Cadillac CTS and I found this http://www.pac-audio.com/swixprogrammin ... les&ID=150 My question is "Connecting the SWI-PS 's steering wheel control input wire to vehicle plug. " where is the Vehicle plug located? Also is says "Connect pin #2 (purple in the 8-pin C3 harness) to accessory +12v" Where is the C3 harness? Last it says "THE ROTARY KNOB IS NOT PROGRAMABLE!" are they referring to the volume knob on the steering wheel? So how will I control the volume? Any help will be appreciated Thanks. Quote Link to post Share on other sites
Blade Posted November 5, 2009 Report Share Posted November 5, 2009 I did a self-install on my 09 Chevy conversion van recently... I had the same problem with the PAC SWIPS instructions regarding the harness. The installer that I bought it from had access to a website (http://www.directed.com/) that told me the location of the harness, but it had the wrong harness color listed. The PAC instructions are correct about the harness you need to interface. I dont know about the rotary knob you are referring to, but if that is how you do the volume, then you might want to skip the SWIPS and consider a different wired remote that takes the place of the steeringwheel controls instead of attempting to interface with them via the SWIPS. VBLUE42 mentioned a Sony product that looked cool in an earlier thread today... also Pioneer makes a marine-remote that has the core basic functions also. Quote Link to post Share on other sites
sopher Posted November 9, 2009 Report Share Posted November 9, 2009 I too am having an issue with the PAC SWI-PSv1 (from Sonic) I connected and follow the instructions. On my F150, the Volume and next/prev track do not work. I also installed the Metra Axxess AFSI-02 kit to restore SYNC. So my Media/Phone buttons on the streeing wheel still work through sync. Any help please? Quote Link to post Share on other sites
VBLUE42 Posted November 9, 2009 Report Share Posted November 9, 2009 One thing I can tell you guys about the PAC modules is that they are very stubborn about how you connect the black ground wire. I had to run a wire straight to the negative terminal of the battery before I could get consistent function from the volume down button. Sometimes it would work and sometimes it wouldn't until I grounded it to the battery. Something you guys might want to try. Quote Link to post Share on other sites
