sotorious Posted November 16, 2009 Report Share Posted November 16, 2009 my text to speech does not work my navi does not talk to me, when i push the button to talk and say commands, the lady does not speak back to me. when i tap on the screen it doesn't make the beep noise. All of the options are enabled and all the volumes are up..... I did do a bypass on it and im wondering if thats the problem, if someone can help me it would be great. Quote Link to post Share on other sites
steve5575 Posted March 13, 2010 Report Share Posted March 13, 2010 Bump. I've got this same exact problem. I too did the hack. Is there any way this hack would cause this to happen? HELP!!! Quote Link to post Share on other sites
VBLUE42 Posted March 14, 2010 Report Share Posted March 14, 2010 No, go through your settings and turn the volume up for navi voice. Quote Link to post Share on other sites
steve5575 Posted March 15, 2010 Report Share Posted March 15, 2010 I have the volume turned up and the beep on. It turns out (after talking to a smart guy at Crutchfield) it is not the unit but the factory wiring of the Jeep. The Jeep's factory amp is a 2 channel that is used to power both front and rear speakers. The Jeep apparently uses the rear speaker leads to the amp. Strange but true. So now all I need to do is swap the fronts on the AVIC to the Jeep's rear leads and presto. I can't do this until tonight but I'm very convinced that this will solve my problem. All you Jeep owners out there that plan to use the factory amp needs to read this for their install! Quote Link to post Share on other sites
