ndy4eva Posted February 8, 2010 Report Share Posted February 8, 2010 I have f500 and x710. My f500 has much better screen contrast thana x710 I just installed. Is there any way to adjust the screen contrast? During the night-time, it's not so bad. But the color looks washed-out during the daytime. Thanks, Quote Link to post Share on other sites
ndy4eva Posted February 9, 2010 Author Report Share Posted February 9, 2010 It seems that it's more to do with the viewing angle issue. My F500BT on Mazda6 is located about eye-level (top compartment), and my x710BT on S-Type is located below. I checked x710BT from eye-level and it seems to have better contrast than viewing from the top-down. Also, I poked around TestMode but couldn't find any settings to adjust the screen other than brightness. Quote Link to post Share on other sites
m5james Posted May 9, 2010 Report Share Posted May 9, 2010 Where did you find these brightness settings? I'm having issues w/ my seating position, the angle of my deck and the picture becoming too dark sometimes. I wish someone would write code to add changes like this into the menus. Quote Link to post Share on other sites
ndy4eva Posted May 10, 2010 Author Report Share Posted May 10, 2010 Where did you find these brightness settings? I'm having issues w/ my seating position, the angle of my deck and the picture becoming too dark sometimes. I wish someone would write code to add changes like this into the menus. Just hold down the map button and it will bring the brightness control menu. There isn't any contrast configuration. Quote Link to post Share on other sites
m5james Posted May 23, 2010 Report Share Posted May 23, 2010 I just went and checked, and I've already got that at 10. What about adjustments in testmode that you mentioned earlier? Is the DVD software based off of some version of Windows Media Player? I'd like it even brighter, I find myself sitting upright and resting my arms on the steering wheel in order to be able to see the screen during darker scenes in movies. Quote Link to post Share on other sites
Zoidbort Posted June 4, 2010 Report Share Posted June 4, 2010 I too am totally stunned that they did not include a Contrast adjustment! The contrast is way too low right now and everything does have a washed out grey hue to it. Turning up the contrast would make the screen look a 100 times better! Quote Link to post Share on other sites
m5james Posted June 20, 2010 Report Share Posted June 20, 2010 Bump. I played around in testmode since I did the FX3.1 upgrade, but I can't see anything that'll let me adjust the brightness on the desktop. I'm guessing this is a coding thing that I have NO clue how to do. Quote Link to post Share on other sites
Guest x5james Posted July 1, 2010 Report Share Posted July 1, 2010 I PM'ed Retell to see if he knows how this can be done since he did such an awesome job making FX3.1. Quote Link to post Share on other sites
narcolept Posted July 1, 2010 Report Share Posted July 1, 2010 No. If you're sitting with your arms on the steering wheel, your problem is the viewing angle in your vehicle, rather than the ability to adjust contrast on the unit. Quote Link to post Share on other sites
Guest x5james Posted July 1, 2010 Report Share Posted July 1, 2010 I'm 6'4" and my deck is at the same angle as the dash, so I agree it's a viewing angle. I've got another bezel on order that tilts it down more, but there are still certain very dark scenes where I'd like to brighten the image above +10. I'm not necessarily worried about contrast, more brightness than anything. If there is an adjustment for that, it would seem that it can be adjusted even more internally so the limit is higher then it's preset to now. Quote Link to post Share on other sites
