jobewan Posted December 8, 2006 Report Share Posted December 8, 2006 Has anyone had their steering wheel remote work intermitantly? I got my Z1 installed today and started using the remote. It seems to work for 10 or 15 clicks and then, the Z1 ignores it for a while. It starts working again after a couple of minutes. Its is VERY strange behavior. I'de appreciate knowing any basic info on the remote too - like, is it an infra red transmit, radio transmit? or ??? Also, what is the model number for the "regular" remote? My unit did not come with any remote and if the steering wheel unit keeps acting up I gotta figure out what else to try. thanks joe Quote Link to post Share on other sites
cntrylvr79 Posted December 8, 2006 Report Share Posted December 8, 2006 http://avic411.com/forum/viewtopic.php? ... ght=remote http://avic411.com/forum/viewtopic.php? ... ght=remote http://avic411.com/forum/viewtopic.php? ... ght=remote Some light reading for you. Should answer all of your questions. Quote Link to post Share on other sites
jobewan Posted December 8, 2006 Author Report Share Posted December 8, 2006 Thanks for the links. I had done a search on "remote" and "remote problems" but too many unrelated messages came up and i never saw those. As for the problems I'm having, they're not sunlight related - I was testing it at night and holding the steering wheel remote right in front of the unit (not attached to the steering wheel) so there was direct line of sight. So .... other insights ? The unit worked, then stopped, then worked then stopped etc. I was using the volume control figuring that was a simple signal that would work in most circumstances on the Z1. Could be a bad unit I suppose. I guess the only way to test that woudl be to try another. Thanks, joe Quote Link to post Share on other sites
cntrylvr79 Posted December 8, 2006 Report Share Posted December 8, 2006 Have you tried replacing the battery. Even though you just got the remote, it may have been sitting for months. Quote Link to post Share on other sites
tillithz Posted December 8, 2006 Report Share Posted December 8, 2006 yep, check the batteries, bad batteries, or even corrosion or such on the contacts of the batteries, I have a remote that if I dont tap it first it will not function. Quote Link to post Share on other sites
jobewan Posted December 8, 2006 Author Report Share Posted December 8, 2006 yep, I have a remote that if I dont tap it first it will not function. Sounds like my 17 year old son. Anyway, I'll replace the batteries and see if that handles the wierdness. Joe Quote Link to post Share on other sites
tillithz Posted December 8, 2006 Report Share Posted December 8, 2006 hehe, right on Quote Link to post Share on other sites
