smrtss1 Posted April 18, 2010 Report Share Posted April 18, 2010 I just picked up a Z110BT and all the interfaces for steering wheel controls, door chimes etc and staring at the seemingly ridiculous amount of wiring I'll have to be doing is a little bit intimidating since its A. a car I LOVE and B. Not a cheap headunit to screw up and have to replace. If anyone has a little experience installing all the interfaces or can let me know of anything that I'll need to do before I get to it to make things go smoother I'd love to hear it. I've got plenty of experience installing stereos and wiring on vehicles but I'm a bit out of practice and I don't want to screw anything up. Any help would be appreciated. Quote Link to post Share on other sites
Morfious Posted April 18, 2010 Report Share Posted April 18, 2010 The illumination wire instructions are incorrect If you install it as instructed it will remain on daytime at all times. You can tie into the rear wiper switch (Brown with white stripe) and hook that up to the illumination wire. That will correct the problem. I have had much success using the following website: http://ss-shootout.com/tunes/index.html The following picture is stolen from there and shows the rear wiper tie in point. Also the dash kit is horrible and will require quite a bit of trimming/hacking in order to make things fit properly and allow the unit to open. Quote Link to post Share on other sites
smrtss1 Posted April 24, 2010 Author Report Share Posted April 24, 2010 Anyone know how tough it is to wire the steering wheel controls or what it even plugs in to? Trust me I'm not a noob to installs I just want to get this right and not burn my SS to the ground (although then I could get a new one) Quote Link to post Share on other sites
