Avy1234 Posted April 22, 2010 Report Share Posted April 22, 2010 First let me thank Dragon24 and Carver. Both the 3.0 install and nag screen tutorials are phenomenal. There is a wealth of information on this site and it is greatly appreciated. I have a F90BT that recently had a reboot problem. In order to fix it I went from 2.006 to 2.008 to 3.00 to 3.02. All went well and cleared up my reboot problem. I also used carvers files to get rid of the nag screen after 3.02 was in. 99% of things work excellent. Even better than before now that I have the updates. My problem is now when my Map is in 3D mode it does not display any of the street names on the map. In the 2D setting it works fine. Is there a setting I have wrong or something that might be causing this? Thanks for the help. Best Regards - Justin - Quote Link to post Share on other sites
whoopidoo2 Posted April 26, 2010 Report Share Posted April 26, 2010 Do a search. Known issue. Quote Link to post Share on other sites
Avy1234 Posted April 27, 2010 Author Report Share Posted April 27, 2010 Can you point me in the right direction? Do I need a hacked ezrider file? I've searched a bit but wasn't positive if that was the issue or if it was something else. Quote Link to post Share on other sites
whoopidoo2 Posted April 27, 2010 Report Share Posted April 27, 2010 No not really. There isn't a fix, though there is some mucking around in sys.txt that might improve it for you a little depending on what you're doing. At the top of this page, in search, type 3d street names. You'll get 30+ pages of results. Sorry but you're going to have to wade through it if you want the full deal. Quote Link to post Share on other sites
Avy1234 Posted April 27, 2010 Author Report Share Posted April 27, 2010 Alright. I'll see what I can dig up on the sys.txt. Thanks. Quote Link to post Share on other sites
