guillaume.db Posted July 22, 2010 Report Share Posted July 22, 2010 Hello I have just bought a F920BT for my GTI. Installation is completed but i have a probleme with the "Car Speed Signal input" and "Reverse Gear Signal input" Could I connect them without can-bus adaptator ? (directly on the instrument panel ?) If you have some information about that... Regards (excuse me for my bad english) Quote Link to post Share on other sites
Baedarlboo Posted July 22, 2010 Report Share Posted July 22, 2010 Not sure on the VSS, but you can tap directly on to the reverse light for the reverse wire. If' things haven't changed between the MKIV and the MKV you should be able to tap the VSS wire directly. Quote Link to post Share on other sites
guillaume.db Posted July 23, 2010 Author Report Share Posted July 23, 2010 VSS is Vehicule Speed Signal ? For reverse gear signal I will try to see if I can take it from DSG box Quote Link to post Share on other sites
