sandro_arellano Posted August 15, 2010 Report Share Posted August 15, 2010 hi, i purchased an avic z2 about a year ago and it works great except for the gps red arrow. the arrow i am talking about is the arrow that represents the vehicle when moving. when i am driving it is pointing in the wrong direction and not in the direction that i am driving. how do i fix this? i have not connected the speed sensor wire so i dont know if this has anything to do with it. please let me know if anyone has any ideas on this. your help is appreciated. sandro Quote Link to post Share on other sites
sandro_arellano Posted August 16, 2010 Author Report Share Posted August 16, 2010 ttt Quote Link to post Share on other sites
jwq Posted August 16, 2010 Report Share Posted August 16, 2010 First of, try a reset. Secondly, it's not a good idea to leave the speedpulse not connected...... connect it, that's what it's for Quote Link to post Share on other sites
EssTEye Posted August 28, 2010 Report Share Posted August 28, 2010 To add, and not to sound like a jerk, did you check to see that you installed your "brain" unit properly? If you installed it backwards, i.e. the -> (arrow) pointing the wrong way, it may show your orientation improperly on your navigation screen. Make sure you have good satellite links, the unit should try to self-correct your orientation if it senses you moving in a particular direction, unless you have the brain unit installed backwards, then it will just think you are going in reverse. Quote Link to post Share on other sites
atunguyd Posted August 28, 2010 Report Share Posted August 28, 2010 there is an option in the menus along the lines of "change current location" when you do this not only can you change your location but also orientation. you might want to try that Quote Link to post Share on other sites
lostinthewoods Posted January 15, 2011 Report Share Posted January 15, 2011 did you ever get this fixed, i am having the same problem Quote Link to post Share on other sites
brax Posted December 19, 2014 Report Share Posted December 19, 2014 like atunguyd said, theres a option under setting to modify current location, hit ok, then it will pop up two arrows on the screen to change directions of the arrow in 360 degs Quote Link to post Share on other sites
