yannthekeys Posted August 18, 2010 Report Share Posted August 18, 2010 Hi everyone, i'm a french "avicist", i've just done the update on my F700BT from 1.9 to 2.009. I use an iphone 3gs, it transfers all the contacts, but when there's an incoming call, even it's from a registered contact, it only displays the phone number. I've searched on this forum but " i still haven't found what i'm looking for..." Quote Link to post Share on other sites
Bento Posted September 13, 2010 Report Share Posted September 13, 2010 I would like to know if this is fixable aswell. Even my old Parrot would display the Caller ID. My F9110 just displays the number, so i have to pick up the phone to see who's actually calling Quote Link to post Share on other sites
yannthekeys Posted September 13, 2010 Author Report Share Posted September 13, 2010 still no solution or answer... Quote Link to post Share on other sites
DJE356 Posted October 2, 2010 Report Share Posted October 2, 2010 For me sometime the name appears sometime not ??? Chez moi c'est intermittent (ça doit venir que j'ai un dossier d'intermittent chez pole emploi !!!) Quote Link to post Share on other sites
buck Posted October 15, 2010 Report Share Posted October 15, 2010 Hi, I had a problem with this and I solved it by making sure that my address book number is exactly the same as what is coming in. Some systems are smart enough to ignore the "+" sign and just match on country code area code and phone number, this isn't. Being in NA I had to make sure that all my numbers in my BlackBerry contacts were in this format: +15145551212 Because when a number was calling me it was coming in as: +15145551212 not as 15145551212 Once I did that it worked, resent my contacts to the AVIC it worked. You might want to give that a try. Quote Link to post Share on other sites
Bento Posted October 15, 2010 Report Share Posted October 15, 2010 Cheers, thanks for the tip. Will try later this weekend. Quote Link to post Share on other sites
