bootay Posted December 27, 2006 Report Share Posted December 27, 2006 Looking for VSS and Reverse wires for AVIC-Z1 install Thanks! Mark Quote Link to post Share on other sites
tillithz Posted December 27, 2006 Report Share Posted December 27, 2006 pioneer will tell you NOT to hook it up and to tuck it in the kick panel. it provides about 3 feet of accuracy and a couple features you probably wont use anyways. Quote Link to post Share on other sites
cntrylvr79 Posted January 4, 2007 Report Share Posted January 4, 2007 2007 Honda Odyssey Speed Sense blue/white PCM, conn. A, pin 29 Notes: The PCM (Powertrain Control Module) is on the passenger side fender. Reverse Light green + dr kick or MICU, 14 pin plug, pin 11 Notes: The MICU (Multiplex Integrated Control Unit) is part of the driver side fuse/relay box. It has two plugs on the side edge of the fuse/relay box. merry xmas Quote Link to post Share on other sites
