DeEePiDDy Posted October 30, 2010 Report Share Posted October 30, 2010 Is there a way to have BOTH a USB input available as well as have the iPod cable hooked up? I see the Kenwoods have both available simultaneously.. can the x920bt do it as well? Quote Link to post Share on other sites
VBLUE42 Posted October 31, 2010 Report Share Posted October 31, 2010 No. Quote Link to post Share on other sites
Jefe21 Posted November 3, 2010 Report Share Posted November 3, 2010 I was going to try and put a 4 port powered USB dock in the Ipod hookup to see if I could plug in the Ipod and have extra ports for a ext hard drive or my Android phone but decided not to. I was told it would work though Quote Link to post Share on other sites
1loudls Posted November 3, 2010 Report Share Posted November 3, 2010 I was going to try and put a 4 port powered USB dock in the Ipod hookup to see if I could plug in the Ipod and have extra ports for a ext hard drive or my Android phone but decided not to. I was told it would work though every body else that has tried it has said that it wont work, the avics dont have the drivers for a USB hub. Quote Link to post Share on other sites
VBLUE42 Posted November 4, 2010 Report Share Posted November 4, 2010 It half ass works to the point that it will be more aggravating then useful. There is also opinion that it could damage the USB function of the unit. Quote Link to post Share on other sites
jp4cy Posted November 4, 2010 Report Share Posted November 4, 2010 every body else that has tried it has said that it wont work, the avics dont have the drivers for a USB hub. That's what I thought too. Quote Link to post Share on other sites
1loudls Posted November 4, 2010 Report Share Posted November 4, 2010 by the way, this is why the USB portion of the ipod cable is so short, so that you can un plug it when you want to and be able to plug in a flash drive so that you can use the same input as both options at the same time, or instead of using a USB flash drive, just use a SD card, thats what most of us do Quote Link to post Share on other sites
