slap01 Posted November 5, 2010 Report Share Posted November 5, 2010 Is there any other way bypass the x920bt without me purchasing another harness Quote Link to post Share on other sites
ObnoxiousDrunk Posted November 5, 2010 Report Share Posted November 5, 2010 Is there any other way bypass the x920bt without me purchasing another harness How bad is the pin? I unfortunately broke the mute pin when I removed it. I grabbed a solder iron and fixed it no problem. I thought I would have an issue, but it has had no apparent affect as my bypass works beautifully. Try fixing it before you buy a new harness. Quote Link to post Share on other sites
JohnnyDepp Posted November 13, 2010 Report Share Posted November 13, 2010 How bad is the pin? I unfortunately broke the mute pin when I removed it. I grabbed a solder iron and fixed it no problem. I thought I would have an issue, but it has had no apparent affect as my bypass works beautifully. Try fixing it before you buy a new harness. Find another wire that's not being used (if any) and remove it. Or, just order wires with connectors already on them. By the way, they sell tools designed to safely remove these pins (even though they're not really made to be easily removable...that's the whole point of Molex-type harness connectors like these). See this thread: http://avic411.com/index.php?/topic/29752-why-not-just-add-a-wire-for-bypass/ Quote Link to post Share on other sites
