raybones Posted February 18, 2011 Report Share Posted February 18, 2011 how can i listen to pandora via usb on my 3200dvd? i have an android phone / mytouch 4g Quote Link to post Share on other sites
VBLUE42 Posted February 18, 2011 Report Share Posted February 18, 2011 Does the phone allow audio output from the USB port? Quote Link to post Share on other sites
rgarjr Posted February 18, 2011 Report Share Posted February 18, 2011 your best bet is probably feed it through 3.5mm to AV input. Quote Link to post Share on other sites
raybones Posted February 18, 2011 Author Report Share Posted February 18, 2011 i haven't tried. how can i check? are there such things as usb headphones? Does the phone allow audio output from the USB port? Quote Link to post Share on other sites
raybones Posted February 18, 2011 Author Report Share Posted February 18, 2011 trying to avoid this way, as i want the phone to charge via usb at the same time. your best bet is probably feed it through 3.5mm to AV input. Quote Link to post Share on other sites
raybones Posted February 18, 2011 Author Report Share Posted February 18, 2011 trying to avoid this way, as i want the phone to charge via usb at the same time. if i purchase this 3.5 male to usb cable, do you think the phone will charge? http://www.officedepot.com/a/products/981492/Accell-USB-Sync-Cable/?cm_mmc=Mercent-_-NexTag-_-Networking_and_Cables-_-981492 Quote Link to post Share on other sites
rgarjr Posted February 18, 2011 Report Share Posted February 18, 2011 No it wont. Just plug in a cigarette lighter charger along with the 3.5mm. If you had the 3200BT with bluetooth u could have probably streamed it through. Quote Link to post Share on other sites
danimal86 Posted February 21, 2011 Report Share Posted February 21, 2011 nope, you cant stream music on the 3200bt. you can if you had the 3200dvd or 4200dvd with the add on bluetooth module. thats what i have and it work for an ipod nicely, but i haven't tried pandora because i dont have a data plan on my phone. Quote Link to post Share on other sites
barney stinson Posted March 22, 2011 Report Share Posted March 22, 2011 forgive my ignorance but i thought this was an iphone-only feature. i'm not aware if the android app also includes the pioneer link which is necessary to control pandora through the radio's interface. Quote Link to post Share on other sites
VBLUE42 Posted March 22, 2011 Report Share Posted March 22, 2011 Pandora control from the unit is iPhone only. Other phone platforms can still be used without control from the unit. Quote Link to post Share on other sites
