mike4100 Posted November 12, 2011 Report Share Posted November 12, 2011 I installed a Z130bt in my 2010 Honda Ridgeline RTL yesterday. I did the bypass mod. Moved the yellow mute wire up one spot then grounded it to the factory harness with the green parking brake wire and the HU`s ground wire. I also connected the speed sensor wire to one of the wheel sensor wires behind the passenger kick panel. When I check the connection status it shows the parking brake is on even when I`m moving, yet I can`t access half of the things in the nav menu until I stop. What is my problem? Thanks, Mike. Quote Link to post Share on other sites
mike4100 Posted November 13, 2011 Author Report Share Posted November 13, 2011 I found that the yellow wire pin wasn't pushed in far enough. I fixed the pin and now I have full control of the nav and can watch dvd's while moving. Now I have to figure out why my deck won't connect to my iPhone 3gs using the Pioneer cable. Quote Link to post Share on other sites
VBLUE42 Posted November 13, 2011 Report Share Posted November 13, 2011 Where did you buy the cable? Quote Link to post Share on other sites
mike4100 Posted November 14, 2011 Author Report Share Posted November 14, 2011 Well it turns out taking strong pain killers for a back injury before installing a new head unit in your car is a bad idea. The plug for the USB wire wasn`t pushed all the way into the HU. I can now connect my IPhone to my deck. Quote Link to post Share on other sites
