axp2948 Posted May 14, 2012 Report Share Posted May 14, 2012 Hi all, I've been wondering to see if this solution will work for what I'm trying to do. My current setup is the AppRadio2 with iPhone 4s using a Mophie Jetpack Plus battery case. With the phone in the battery case, I will not be able to use the iPhone cable to use APPS on my radio unit unless I take the phone out of my battery case. This is because the battery case has a micro usb port instead of the traditional apple dock. I came across this product CableJive dockBoss+ which allows you to connect any micro usb device to use with a apple dock. Do any of you know if this will work with our head units so I do not have to keep taking my phone out of my battery case? The product link can be found here: http://www.cablejive.com/products/dockBossplus.html Thanks, Alex Quote Link to post Share on other sites
