S95Sedan Posted July 20, 2012 Report Share Posted July 20, 2012 Update 21-05-2013: Added the files as an attachment, pass is 'avic411'. Currently there can be some issues, i have done 90-95% of the the files so everything should look fine. Avic_Net section isnt done yet. Forgot to add but the borders around the icons are gone as well as some other subtile changes. They are not shown in the screenshots. ----- Just thought i'd share some of my work on here, currently work in progress still. Even though it's running not on the machine itself i would assume it wouldn't be a problem to do so. (havent had the chance yet to do so)Mainmenu is nearly finished, custom icons, custom text, background color fixed. (I'm using the Avic Net version so thats what its going to be based on)Mainmenu:Mainly doing this because im fed up with the oem skin and wanted something more fresh.It's done when done. Currently very busy renovating my house aswell but hoping to have some more stuff ready in the next couple days/weeks.---------------------------------------------------------------------------Mainmenu hacks: (Use them with caution)Backup your files!---------------------------------------------------------------------------Background color of the mainmenu:- Open the file ..\APL\MainRes.res and extract the content.- Open the MainRes folder extracted- In your Hexeditor open the file: 'Main.cmf.bpnd'- Go to Offset: 196762 [0x003009A]- Find the colorcode of the background you, for example #1D272C- Since for some weird reason the pioneer reads these numbers in reverse, flip the first and last two digits. [For example 2C271D]- Input these digits at the offset a bit above here,only change the 0000 00 (Currently is should read 0000 00FF 01 ect.)- Save your file and repack it with 7zip.---------------------------------------------------------------------------Custom Mainmenu text:(Just taking the mainmenu's 'destination' text for example here)- Open the file ..\APL\MainRes.res and extract the content.- Open the MainRes\Tables folder extracted.- In your Hexeditor open the file 'StringTable.str.pnd.bpnd'- Go to Offset: 209744 [x00033350]- If correct it should display: 'D.e.s.t.i.n.a.t.i.o.n.'- Since each letter is followed by 00 you get this weird looking word.- Replace whichever word you want there, after each letter add 00.- Now we want to find Offset: 209740 [0x0003334C]- Should read 0B- This value represents the length of the word we just put there, spaces included.- So lets say we changed it to 'Mainmenu' wordlenght being 8, we change that value to 08.- For longer wordt just convert whichever number you have to a hexidecimal value.- Save your file and repack it with 7zip. Pioneer F900Bt - Skin v1.0.rar Quote Link to post Share on other sites
T S Posted January 16, 2013 Report Share Posted January 16, 2013 I think i found the color in this location. Haven't tested. see attached. Quote Link to post Share on other sites
longerz Posted January 20, 2013 Report Share Posted January 20, 2013 How do you do this look very good i would just swap the source icon an is the able to be downloaded Quote Link to post Share on other sites
S95Sedan Posted February 15, 2013 Author Report Share Posted February 15, 2013 Been a long while since i continued this but picked up a couple weeks ago. Mainly been testing it on the unit itself now since i got my bench setup finally working properly. Also made some modifications to the coding of 'Avic Net 2.1' since it is just a bunch of cluttered files. Hoping to have alot of it cleaned up afterwards. Some pictures of the progress; (Dont mind the text, it's currently on dutch) Quote Link to post Share on other sites
Atteman Posted February 18, 2013 Report Share Posted February 18, 2013 thumbs up Quote Link to post Share on other sites
noobnoobi Posted March 14, 2013 Report Share Posted March 14, 2013 Been a long while since i continued this but picked up a couple weeks ago. Mainly been testing it on the unit itself now since i got my bench setup finally working properly. Also made some modifications to the coding of 'Avic Net 2.1' since it is just a bunch of cluttered files. Hoping to have alot of it cleaned up afterwards. Some pictures of the progress; (Dont mind the text, it's currently on dutch) Wow hier zit ik al even op te wachten!! wanneer komt het eindresultaat? i love it Quote Link to post Share on other sites
peter s Posted March 22, 2013 Report Share Posted March 22, 2013 hi s95sedan, although i am not exactly drowning in spare time: how can i help you to advance faster? regards peter Quote Link to post Share on other sites
carbonr Posted May 10, 2013 Report Share Posted May 10, 2013 Any update, I can help with new icons if you can share dimensions Quote Link to post Share on other sites
S95Sedan Posted May 21, 2013 Author Report Share Posted May 21, 2013 Added the files to the first post. 90-95% complete. Any new versions will be added in this topic incase i do get to it to update them. Currently only the english text has been changed so it's advised to use english as language setting. Any other language will display the old text strings. Find any bugs? Let me know so they can be changed. Also some private things going on at the moment so haven't found the time yet to continue. Quote Link to post Share on other sites
