drozovs Posted February 6, 2007 Report Share Posted February 6, 2007 I conected my XM module to my Z1 and it says not present... both cables where used but not the IP power bus as stated in the manual. Any help? Thanks! David Quote Link to post Share on other sites
cntrylvr79 Posted February 6, 2007 Report Share Posted February 6, 2007 Yeah you have to hook up the power cable. Yellow to constant, black to ground. The red wire is te only one you don't hook up. Quote Link to post Share on other sites
Egmont Posted February 15, 2007 Report Share Posted February 15, 2007 Yeah you have to hook up the power cable. Yellow to constant, black to ground. The red wire is te only one you don't hook up. I hooked mine up and the unit works, well, I got a bad antenna, but that does not count, I think? What is the reason for not connecting it? Quote Link to post Share on other sites
cntrylvr79 Posted February 15, 2007 Report Share Posted February 15, 2007 Not connecting the red wire? It's meant for a standalone when you're not using the ipbus. Quote Link to post Share on other sites
Egmont Posted February 15, 2007 Report Share Posted February 15, 2007 Not connecting the red wire? It's meant for a standalone when you're not using the ipbus. Thanks, should I disconnect it since it is part of a bus or does it not matter? Quote Link to post Share on other sites
cntrylvr79 Posted February 15, 2007 Report Share Posted February 15, 2007 I'd disconnect it. Don't know for sure if it will cause any problems in the long run, but better safe than sorry. Quote Link to post Share on other sites
