X850bt GPS won't move
I'm new to this forum, just installed the x850bt. Everything works great except the GPS. The map itself is stuck on the location I was when I installed the unit. The arrow and map won't move when I drive. I drove a few miles away then input where I was when I installed the unit to guide me and it just tells me I'm already there.any input would be appreciated. Thanks
I literally just installed my 850bt yesterday, have the GPS antenna under the dash as well. It's probably not as strong as a connection as it would be outside, but it still picks up 5+ satellites. Takes a few minutes longer the first time you hook it up, I think.
Did you mount it on the little metal sticker plate they sent? I have read that helps.
