Kloaked00 Posted April 16, 2013 Report Share Posted April 16, 2013 (edited) After running to the store earlier today, my F700BT seems to have become unfunctional. My unit will turn on when I turn on the car, show the splash screen for about 20 seconds then shut off. The lights for the buttons shut off as well and pressing the buttons does nothing. My unit is un-hacked, the only changes I made were to use custom images for the splash screen and menu icons, and replace the navigation sounds with blank sound files. After some searching on the forums, I found several other threads with similar problems so I've been trying to work through the various fixesposted. Unfortunately, nothing has seemed to work so far. I'd like to be able to try the Basic Reboot Loop Fix, but when I boot into testmode, the Windows CE desktop only for a second or two before the unit shuts off again. As far as I can find, that's not quite exactly the problem that other people were having, so I'm unsure if my issues is a common one, or a brand new problem. I have also tried back-updating to the 2.006 firmware. I loaded it onto the SD card, put it in but almost immediately at 1% the black background turned red and it didn't go any further. I know it didn't freeze because the Used Time and Possible Remain Time continued to both count upwards with each passing second. I'm hoping that didn't cause even more problems. I'm in the process of downloading the files from the FormatMBR thread, but really would like to avoid the 'nuclear' option if possible. If anyone has any ideas of what's going on, or other things I could try before I follow the FormatMBR instructions, I'd really appreciate it. Edit: Tried the 2.008 firmware as well, and it seems that both firmware versions get the error "Copying error: Storage Card | LPUE080 | APL | Images.Res" when trying to update Edited April 16, 2013 by Kloaked00 Quote Link to post Share on other sites
Kloaked00 Posted April 16, 2013 Author Report Share Posted April 16, 2013 After getting frustrated I took an hour break and came back for some more searching and found Retell's complete 3.1 update from this thread: http://avic411.com/index.php?/topic/27807-fx31-complete-firmware-image/page-1 Worked like a charm and my unit is working perfectly again. Thank you Retell Quote Link to post Share on other sites
