ermartin Posted March 2, 2007 Report Share Posted March 2, 2007 Has anyone successfully calibrated an N1 screen. I have attempted this for hrs and it never gets any better. will a complete reset help at all ? Quote Link to post Share on other sites
fieldsinv Posted July 12, 2007 Report Share Posted July 12, 2007 Follow the instructions by REMIX2112 posted Nov 2006. I just did it today and it worked. I learned that all you have to do is press (EQ) botton and then (BAND) to go back in the menu. If you are off alot, I found that all need to do is not trace the outer white line. Just place your pointer a cm from the side. I just used a pointer once at the bottom and once at the top. The values changed ok. **It took me 3 times to figure it out.** Quote Link to post Share on other sites
Tone-Dogg Posted August 14, 2007 Report Share Posted August 14, 2007 That still isn't working for me. Is it possible that my screen is just to far gone, or do I need to have the flex cable done first before, I can recal. The screen is stuck in the up position and +- don't work any more. Sorry to highjack the thread Quote Link to post Share on other sites
rford41 Posted March 27, 2009 Report Share Posted March 27, 2009 I ran into the same problems calibrating on the left side. I slightly lifted the plastic along the left edge and used a thin stylus. (consider that there is more screen continues under the edgeing). It worked and I was able to complete the calibration process. Quote Link to post Share on other sites
