barnestormer Posted April 14, 2017 Report Share Posted April 14, 2017 If you're using a mac, the USB drive will have hidden extensions as part of Spotlight, etc. Easy fix is to not use a mac. If you use a mac, download the file to your usb, then insert it in a windows pc. Enable hidden folders and delete all folders except your update. or you can get really technical on a mac. Put the update on the usb, then run terminal: Open Terminal, type: cd /Volumes/<your thumb drive> then type: rm -rf ._.Trashes .Trashes/ .Spotlight-V100/ .fseventsd/ Then eject the disk. You should now have ONLY the firmware folder on it. Quote Link to post Share on other sites
Join the conversation
