WRichieX Posted April 3, 2007 Report Share Posted April 3, 2007 Can anyone please help me out. Where can I find these wires. Thanks Quote Link to post Share on other sites
boostaddict Posted April 3, 2007 Report Share Posted April 3, 2007 Replied to your post on NASIOC also. VSS: Two places, depending on how you want to run your wire. 1. Cruise control module, above driver's side kick panel, pin 19, Green/Yellow. 2. ECU, facing the side with the connectors, it is the far right connector, pin 1 (far right top wire), Green/Yellow. I chose the ECU because it was easier to get the wire over to the nav unit. Reverse: Behind passenger side kick panel, in the rearward harness, Light Brown/Yellow. I didn't hook the reverse up because I didn't know where it was at the time. The AVIC-D3 works fine without it, unless you're hooking up a rear camera. PM your email address if you want the wiring diagrams. Quote Link to post Share on other sites
cntrylvr79 Posted April 6, 2007 Report Share Posted April 6, 2007 Reverse Light brown/yellow + passenger kick, harness to rear merry xmas Quote Link to post Share on other sites
boostaddict Posted April 6, 2007 Report Share Posted April 6, 2007 Reverse Light brown/yellow + passenger kick, harness to rear Umm, that's what I said. Post whore much? Just messing with you man. Quote Link to post Share on other sites
cntrylvr79 Posted April 7, 2007 Report Share Posted April 7, 2007 No I only read the last 2 lines of the post. Quote Link to post Share on other sites
applehat Posted April 8, 2007 Report Share Posted April 8, 2007 does this apply to an 06 STi also? Also..pics? =P Quote Link to post Share on other sites
