avicer Posted April 27, 2007 Report Share Posted April 27, 2007 does anyone know where i can find the speed sensor cable in this car? been googling and searching forums, but no luck... thanks. Quote Link to post Share on other sites
MisFit Posted April 27, 2007 Report Share Posted April 27, 2007 Speed Sense brown data link connector, pin 11 The data link connector is under the driver side dash in the fuse box opening Quote Link to post Share on other sites
avicer Posted April 27, 2007 Author Report Share Posted April 27, 2007 thanks misfit! do you know by any chance how i would "tap" into that wire? should i just split the cable and connect to avic? Quote Link to post Share on other sites
Striker317 Posted April 27, 2007 Report Share Posted April 27, 2007 The D3 unit comes with all the parts. You should not have to cut any existing VSS cable at all. There should be a pink clip thingy. That's what you use (see the instructions). Quote Link to post Share on other sites
avicer Posted April 27, 2007 Author Report Share Posted April 27, 2007 i have seen that clip thing. so that clip goes directly into the vss cable on the car side? i have not seen the vss cable yet, so i don't know what it looks like. Quote Link to post Share on other sites
