ReeferMAdness Posted June 19, 2007 Report Share Posted June 19, 2007 OK so i got my d3 yesturday my wiring harness and mounting kit i was soo happy that dimished quickly once i had everything wired up and the deck wouldn't light up at all. Now there are some wires i didn't hook up but that shouldn't make a difference......the pink car speed signal input and the violet/white reversegear signal input. other wise everything is as it should be besides the bypass. I took the green long wire and the mute wire and grounded it to the black cable on the wiring harness(after moving it up one slot). Now theres also an auto-antenna relay thats not connected up i have an 06 mustang and there is no auto antenna. If you guys need more info pls ask but im flat out of ideas the thing wont turn on period. Thanks in advance Quote Link to post Share on other sites
cntrylvr79 Posted June 20, 2007 Report Share Posted June 20, 2007 Check All of the fuses in the car. Betcha one's blown. Quote Link to post Share on other sites
ReeferMAdness Posted June 20, 2007 Author Report Share Posted June 20, 2007 wow do i feel like an idiot it was a blown fuse and after all the time i spent rewiring thinking i did something wrong. Thanks man! Quote Link to post Share on other sites
