petershin_95 Posted July 7, 2007 Report Share Posted July 7, 2007 on the left side of my screen when i touch it, it thinks im touching about an inch to the right..... does anyone know the right way to recalibrate the freaking screen?!!! i followed the direction on the bottom, and it does not work! im so fed up with pioneer products failing and having problems, now wonder why alpine is #1 Quote Link to post Share on other sites
blackbox Posted July 12, 2007 Report Share Posted July 12, 2007 i'd say send it back if you just got it! call pioneer to see how you can fix it or have it replaced... Call (800) 421-1404. good luck! Quote Link to post Share on other sites
fieldsinv Posted July 12, 2007 Report Share Posted July 12, 2007 Follow the instructions by REMIX2112 posted Nov 2006. I just did it today and it worked. I learned that all you have to do is press (EQ) button and then (BAND) to go back in the menu. If you are off alot, I found that all need to do is not trace the outer white line. Just place your pointer a cm from the side. I just used a pointer once at the bottom and once at the top. The values changed ok. **It took me 3 times to figure it out.** Save your money... Quote Link to post Share on other sites
