Bastinado Posted August 3, 2007 Report Share Posted August 3, 2007 So I think I'm like 90% done with the install of my D3 into a 2003 mustang GT with the Mach 460 System. Just a couple questions: I have the Metra 70-5519 harness all soldered and connected up, with the exception of a few wires- the dimmer wire (orange with black stripe), and the Amp Turn ons(Light blue wires) and negative wires(black wires). For the Amp turn ons, where should I connect them? I was thinking I could just tap the red ACC wire, but would like to check with you guys first. Also, can I just ground out the negatives then? The entire 8 Pin connector and harness part has got me all confused, any help is greatly appreciated. Also, do I have to connect the dimmer wire to something in order to have the illumination work properly? Thanks for any help! Quote Link to post Share on other sites
djoker04 Posted August 3, 2007 Report Share Posted August 3, 2007 So I think I'm like 90% done with the install of my D3 into a 2003 mustang GT with the Mach 460 System. Just a couple questions: I have the Metra 70-5519 harness all soldered and connected up, with the exception of a few wires- the dimmer wire (orange with black stripe), and the Amp Turn ons(Light blue wires) and negative wires(black wires). For the Amp turn ons, where should I connect them? I was thinking I could just tap the red ACC wire, but would like to check with you guys first. Also, can I just ground out the negatives then? The entire 8 Pin connector and harness part has got me all confused, any help is greatly appreciated. Also, do I have to connect the dimmer wire to something in order to have the illumination work properly? Thanks for any help! My 1st Q to u is why are these wires left FREE? There should be a wire for each. Is it a factory Amp? If so then you should match it up with the remote wire from the factory harness. Do not attach it to the acc wire. If it's aftermarket Amps then use the turn on wire from there. s for the Ground use the ground from the factory harness. Yeah you could GROUND them some where but the best location is from the factory harness. Quote Link to post Share on other sites
installthis06 Posted August 3, 2007 Report Share Posted August 3, 2007 Yea let us know if you get a loud pop from the speakers when ever the radio turns on too. Quote Link to post Share on other sites
cntrylvr79 Posted August 3, 2007 Report Share Posted August 3, 2007 FYI the orange/black wire is a negative dimmer. Just tape it up. Don't need it. There's nothing in an aftermarket radio that you'd need that wire for. Quote Link to post Share on other sites
Bastinado Posted August 3, 2007 Author Report Share Posted August 3, 2007 It is the factory amps from the Mach 460 system, I should have mentioned that before, my mistake. With the connector that has the 2 RCA plugs attached to it, the amp turn on wires get connected to where? (connector on one end, the other end is free right now.) The power connector is all set then for me, matched the wires by color, and taped up the orange/black dimmer wire as cntr said to. That just leaves the last connector. The RCA plugs will be connected to one of the D3s RCAs(which one?), The Amp turn on wires will go to the blue/white system remote wire (lost the tag on it, over looked it completely- HUGE MISTAKE), and then just ground the amp negatives- and I'll be all set? I see some posts about a 2.2 k resistor being soldered in between the amp turn ons and the remote wire- this prevents the turn on POP noise? Is that noise guaranteed? If so I guess I'm running to radio shack for 2 2.2k resistors. Thanks a lot for the help!! Quote Link to post Share on other sites
installthis06 Posted August 3, 2007 Report Share Posted August 3, 2007 Yea the resistors are needed because the newer ford systems use a 6v amp turn on, as opposed to a 12v turn on that the aftermarkets use. Resulting in a POP whenever you turn the radio on..really annoying Quote Link to post Share on other sites
