hooking woofer up to d3
ive got everthing hooked up but i hooked up my rca cables to the subwoofer cables, and i get nothing coming from the subwoofer. i have a blue and a red rca cable running from the amp and i have the plugged into the subwoofer/non fading cables. could this be because my ground wire is not grounded properly, right now im clueless. what could it be, i have a 2004 chevy silverado no bose or onstar.
i have an 800watt powerbass amp and 2 10in mtx subwoofers
Is this a new set-up, or an old set up with a new headunit? If it is a whole new system just start from the beginning and check all of your connections.
Make sure:
There is power to the amp
It is properly grounded
RCAs are hooked up tight
Speaker wire from the amp to the box, the box to the subs
Remote turn on is hooked up
Settings on the AVIC have the amp on (I don't know where this would be, but its a possibility)
If its just a new head unit, I would probably check the last two of that list first.
