CLVNGR Posted August 22, 2007 Report Share Posted August 22, 2007 I've been reading through this Forum (which is AWESOME by the way), and I just want to make sure that my VSS is located at PCM under the hood on the driver side firewall. Is this correct? I don't want to mess something up. I don't have an overhead system, if this helps. I've installed tons of stereos, but no GPS systems. Also...since I'm using the stock speakers with a wire harness adapter, do I need to use the RCA connecter wires? The only reason I can see is to do the Yellow/Black wire Bypass, but if there's another reason why I need it...please tell me. I was just trying to avoid all the wires behind the deck if I didn't need them. Again, thanks for any helpful info, and keep up the GREAT site...VERY helpful. Quote Link to post Share on other sites
MisFit Posted August 23, 2007 Report Share Posted August 23, 2007 Speed Sense gray/black instrument cluster or Also found at the radio on vehicles that have the in-dash CD changer. you only need that plug for the bypass if your not using any amps Quote Link to post Share on other sites
CLVNGR Posted August 23, 2007 Author Report Share Posted August 23, 2007 Thanks a ton... Quote Link to post Share on other sites
