GarrettF Posted August 31, 2007 Report Share Posted August 31, 2007 I recently swapped form an N2 to a D2 and i transfered the working speed pulse wire to the new unit. The speed pulse is no intermittent. i checked the wire throughout the car and it is not snagged or cut and it is securely hooded into a proper seed wire. Could the bypass be causing the problem? Quote Link to post Share on other sites
idbl_fanatic Posted August 31, 2007 Report Share Posted August 31, 2007 What is the exact problem? Quote Link to post Share on other sites
GarrettF Posted August 31, 2007 Author Report Share Posted August 31, 2007 well, the speed pulse is intermittent, i worked perfectly with my N2 but now with the D2 it is intermittent. Also, the unit wont learn 3d, it has plently of dots for speed, left and right and the mode says simple hybrid but i want 3d hybrid and a speed pulse that is working so that the nav is more accurate the only mod to the unit is the bypass and the parking brake is grounded Quote Link to post Share on other sites
