crom! Posted April 14, 2016 Report Share Posted April 14, 2016 I have the yellow wire connected to the ignition switch line, the red wire connected to constant power wire, and black wire connected to the car's ground wire. The unit will not turn on unless the ignition is switch to ON or if the car is running. If I disconnect the constant power wire then every time I start car the unit will go into setup mode. However, with the battery wire connected the unit go straight into operation every time I start the car. So my question is, how do I get the unit to turn on without needing to turn the car on? My old radio would turn on without needing the car key switching the ignition to AC or on. Quote Link to post Share on other sites
kush1007 Posted April 15, 2016 Report Share Posted April 15, 2016 I have the yellow wire connected to the ignition switch line, the red wire connected to constant power wire, and black wire connected to the car's ground wire. The unit will not turn on unless the ignition is switch to ON or if the car is running. If I disconnect the constant power wire then every time I start car the unit will go into setup mode. However, with the battery wire connected the unit go straight into operation every time I start the car. So my question is, how do I get the unit to turn on without needing to turn the car on? My old radio would turn on without needing the car key switching the ignition to AC or on.[/quot From your description it seems you have the yellow and red backwards. Yellow is constant power red should be hooked up to your ignition switch and voilà ..... Quote Link to post Share on other sites
Sparky 1320 Posted April 15, 2016 Report Share Posted April 15, 2016 From your description it seems you have the yellow and red backwards. Yellow is constant power red should be hooked up to your ignition switch and voilà ..... ^ This Quote Link to post Share on other sites
crom! Posted April 18, 2016 Author Report Share Posted April 18, 2016 Thanks guys!! I had the wires switched. works now Quote Link to post Share on other sites
