AversionPictures Posted April 28, 2016 Report Share Posted April 28, 2016 Good morning everyone ! I apologize ahead of time for I know this has probably already been covered somewhere else in this forumn (I can't find it). I'm having major issues upgrading my firmware on my 8000NEX to 1.11 from 1.10. Can anyone give me some instructions as to what I'm supposed to do with my flash stick and the file I downloaded from Pioneer ? Thanks in advance ! -Colin Quote Link to post Share on other sites
Multitask Posted April 28, 2016 Report Share Posted April 28, 2016 8000 and 8100 are the same as far as the following go http://www.pioneerelectronics.com/StaticFiles/PUSA/Car_Electronics/Firmware%20Update%20Files/AVICSYNC/15AVN_FW_Update%20Instructions_16G.pdf Quote Link to post Share on other sites
AversionPictures Posted April 28, 2016 Author Report Share Posted April 28, 2016 What goes on the root of the sd card though ? That's what is tripping me up. Thanks ! Quote Link to post Share on other sites
AversionPictures Posted April 28, 2016 Author Report Share Posted April 28, 2016 Not sd card... I meant to type flash stick. Quote Link to post Share on other sites
Sparky 1320 Posted April 28, 2016 Report Share Posted April 28, 2016 Keep clicking into the downloaded zip file until you get to the folder labeled "AVIC5000NEX". That is the folder you want to put on your SD card. Make sure there is nothing else on the card prior to putting the folder on it. (I always go so far as to reformat the SD Card just to be sure.) And I recommend using an SD Card instead of USB stick. Quote Link to post Share on other sites
BigCiX Posted April 28, 2016 Report Share Posted April 28, 2016 Those instructions will go for the 7000 too right Quote Link to post Share on other sites
AversionPictures Posted April 30, 2016 Author Report Share Posted April 30, 2016 When I put the "AVIC5000NEX" folder on the root of the sd card, it gives me this pop up error.... "Update File Version Error Please check the version of update file and try again." What can I do to fix this ? Thanks ! Quote Link to post Share on other sites
AversionPictures Posted April 30, 2016 Author Report Share Posted April 30, 2016 The error is what shows up on the 8000NEX after I press "Continue" with the firmware update. It won't let me get past that. If anyone has any suggestions I would greatly appreciate it. Quote Link to post Share on other sites
Sparky 1320 Posted April 30, 2016 Report Share Posted April 30, 2016 When I put the "AVIC5000NEX" folder on the root of the sd card, it gives me this pop up error.... "Update File Version Error Please check the version of update file and try again." What can I do to fix this ? Thanks ! I've never seen this before. But "Version Error" would lead me to doublecheck firmware revision levels both on what is already installed on the unit and what you're trying to install. What firmware revision is your unit currently at, using the first two pages of this document as reference: http://www.pioneerelectronics.com/StaticFiles/PUSA/Car_Electronics/Firmware%20Update%20Files/AVICSYNC/14AVN_FW_Update%20Instructions_16G.pdf Quote Link to post Share on other sites
Multitask Posted May 2, 2016 Report Share Posted May 2, 2016 When I put the "AVIC5000NEX" folder on the root of the sd card, it gives me this pop up error.... "Update File Version Error Please check the version of update file and try again." What can I do to fix this ? Thanks ! That would make me think either you already have the version you are trying to install, OR, you downloaded the wrong file... Make sure you got it from here... http://www.pioneerelectronics.com/PUSA/Car/NEX/AVIC-8000NEX?tab=firmware Quote Link to post Share on other sites
