another illumination problem
WTF!!!! Ok heres another one. I have the illumination wire hooked up correctly and even tested itat the harness and it reads 12v when the lights are on, 0v when lights are off. However i do not notice any difference when i change my light switch. I do notice a difference regaurdless of light switch when i cover the light sensor on the flip up screen. if i cover it, it dims down to the lowest setting and if i let light in it goes up to the brightest setting. Now my question to you is what the hell is going on. I got the sub dimmer thing turned on, is there anything else i need to do, this is driving me insane, its the last wire i have had problems with and if i can figure this thing out my install will be totally complete.
I have the cd-vc1 and it seems to be a pain in the ass more than its worth by the way. Other than that everything is good to go
