VSS wire location on 04 Maxima w/BOSE...Help!
Also, one other thing. Sorry for the dumb question but I'm assuming I want to splice into the wire going INTO the module and not going out? The only reason I wasn't sure on this is because I'm assuming that the SSV wire also go to the radio wire harness and I didn't know how all that wiring worked. So I just wanted to double check.
So if the VSS wire is not hooked up will that mainly effect ETA's and things like that? Does the unit still track speed through the GPS or would I need to connect the wire for that too? If I could get a definate location and wire color for the VSS I think I could do the hookup up, just haven't found it yet.
Apparently my bypass isn't working correctly now though. After I started driving I got an error message about the parking brake lead not being hookied up correctly...suppose I have a loose connection somewhere : (
