Avic-D1 GPS navigation - touch screen calibration
By PawelP · Jan 07, 2008in Problems/Troubleshooting💬 7 posts👁️ 12,558 views
Posted Jan 07, 2008 · 05:33 UTC#1
Please help.
My AVIC-D1 touch screen seems to dis-calibrate itself and now there is
very poor pointing accuracy. The center of the screen reacts properly,
but the sides of the screen is off towards the edges. I need to touch
the area outside the point I want to activate. The points close to the
edge are not accessible.
This failure appeared few month after the warranty went out.
Please advise what can I do with this unit. Maybe someone can provide with the calibration routine I can run on my AVIC-D1 to calibrate the
screen.
Thanks in advance
Pawel
Posted Jan 07, 2008 · 17:46 UTC#4
I did that, it worked for the first time!
thank you so much.
I have been trying to contact Pioneer for half a year now about that issue and it took exactly 5mins. to fix it with the self-calibration.
I read Pioneer will charge $200 for that plus all the hassle with removing of the unit from the dash etc.
They should give this routine in the user manual.
Anyways, thanks a lot for this wonderful help, it is great!
Just to reapeat what was already written in the link kindly given to me:
- hit eject & reset at the same time
- release 'reset'
- screen went in & came back out
- screen said "press reset" or something to that effect
- i used the joystick - up, up, down, down, [and then pushed in the joystick to 'enter']
- goes into the service menu - select top option for touch screen
- in touch screen menu, select 1st [top] item with * next to it
- using your fingernail, trace the edges of the screen, and the X,Y values will change to reflect the tracing (I did this a few times to make sure it read my finger well)
- hit the "BAND" button [acts as 'back']
- select the second option down
- select the cross on the screen each time it appears - it will do a column on the right, middle, left, then one final offset just right of the left column - then it should say 'ok' or something like that
- I then selected a menu option (sorry I don't specifically remember the title) with 'Confirm calibration' or something like that in the title - apparently this saved the new settings
- I then removed the faceplate to shut down the unit and put it back on - it went through a few startup sequences and then, after resetting some basics, the unit worked fine (I did it another time where I turned off the engine instread of removing the faceplate)
cheers
Pawel
Posted Jan 26, 2008 · 16:11 UTC#5
sorry for reviving a dead post but were is the reset button on the d-1?
Posted Jan 26, 2008 · 16:29 UTC#6
it's the little intentation by the knob on the left side.
Posted Feb 27, 2008 · 06:12 UTC#7
thank you so much.
I tried it for an hour today, and I can not for the life of me get into the Service Menu. I open the screen on my D1, the press Reset and Eject at the same time, then let go of the reset buttion while still holding eject? What am I doing wrong. It does nothing. Resets, stays blank until I get of of eject. Help!!! My calbriation is off, and its driving me nuts!
