remix2112 said:
I had the same problem but figured out how to fix it with a side effect - the +/- buttons on the unit do not work so the screen in slammed back against my dash when open - I got into the secret service menu on my N1:
- hit eject & reset at the same time
- release 'reset'
- screen went in & came back out
- screen said "press reset" or something to that effect
- i used the joystick - up, up, down, down, [and then pushed in the joystick to 'enter']
- goes into the service menu - select top option for touch screen
- in touch screen menu, select 1st [top] item with * next to it
- using your fingernail, trace the edges of the screen, and the X,Y values will change to reflect the tracing (I did this a few times to make sure it read my finger well)
- hit the "BAND" button [acts as 'back']
- select the second option down
- select the cross on the screen each time it appears - it will do a column on the right, middle, left, then one final offset just right of the left column - then it should say 'ok' or something like that
- I then selected a menu option (sorry I don't specifically remember the title) with 'Confirm calibration' or something like that in the title - apparently this saved the new settings
- I then removed the faceplate to shut down the unit and put it back on - it went through a few startup sequences and then, after resetting some basics, the unit worked fine (I did it another time where I turned off the engine instread of removing the faceplate)
I tried this a few days ago and didn't do the confirm selection (nothing looked logical) and I was able to side-scroll through the main menu pages (3 of them) - when I was done i hit the 'reset' button, and that didn't help anything, but the system rebotted and behaved exactly as it did before (with the screen offset problem still there)
when I tried it this time, the +/- buttons on the fron immediately stopped working, and while I am able to scroll up and down in the system menu with the joystick, I cannot go to the other 2 menu pages! so this is the last thing to fix, and I have saved myself $200 - hopefully I can find a fix - otherwise.....I may be out $200!!
I hope this helps
its good information, however, i will not be attempting this. i actually need those +/- buttons. if there isnt a fix for this i may upgrade within 6 months or so.
the only part that bugs me is when i scroll through my destinations. typing in addresses and numbers is not that bad, i can get through that.
good info though.
i had my navi installed by a shop becuase my car was brand new and i didnt want to take a chance screwing anything up. so in order for me to have this fixed, i would need to pay 220 to get it removed, i guess 200 for repairs, not including shipping, and 220 to get it installed again. for almost 1k, this isnt worth it.
plus, i am thinking about getting a new car, so if i decide not to get a new car, i think i will upgrade.
