Hi all! New to this site, and I must say you guys are amazing!! I just bought a Z2 made in April, and the 2 wire bypass worked flawlessly first time without even needing to update!
I am not sure my VSS wire is hooked up correctly however. I didn't hook it up until the second day I was using it. I have had it in for several hundred miles and about 1.5 weeks... When I look at the diagnostics, I have gotten about 60 speed pulses, but in the list of things that are/aren't connected, there is always a zero next to the Speed sensor...
Also, the learning mode says "simple hybrid." Isn't this supposed to change to 3D hybrid when the VSS wire is hooked up?
Do I need to reset it since I hooked up the VSS wire after the unit had already started learning mode?
But my main question is, do I even have the right wire?? I went with Crutchfield's info that it is a Green/Black wire behind the instrument cluster (speedometer). The people that installed my alarm gave me a printout that said it was a Yellow/Grey (i think) wire behind the glove box. I talked to Subaru and they said it was Pin #13 on the B136 ECM under the passanger side carpet...
AAGGHHHH!!! Any help would be greatly appreciated!!
