2005 chevy tahoe vss wire help
By Daddywarbucks · Feb 11, 2008in Vehicle Specific Wiring💬 4 posts👁️ 1,805 views
Posted Feb 11, 2008 · 04:09 UTC#1
searched and searched im tired.....
Posted Feb 11, 2008 · 11:43 UTC#3
Speed Sense dk. green/white 4K instrument cluster, pin A4 or PCM
The PCM (Powertrain Control Module) is in the left front of the engine compartment to the left of the fan shroud. The VSS wire is in the green plug, pin 50. Also found at the radio harness, on some models.
Posted Feb 11, 2008 · 14:48 UTC#4
Thank you, Thank you, Thank you
