Local Radio stations very bad
By junior · Feb 11, 2008in General💬 8 posts👁️ 939 views
Posted Feb 11, 2008 · 10:12 UTC#1
i just installed my avic d3 on a 02 mustang and all my local radio stations sound very bad. what can it be i plugged the antenna all the way in.
Posted Feb 11, 2008 · 23:19 UTC#3
i have an 02 mustang from what i knowi dont think it has a booster it just had a big orange cable for the antenna witch its plugged in right. the only cable left on it is the antenna control cable is that the one you are talking about. where would it go plugged in in my mustang
Posted Feb 12, 2008 · 00:53 UTC#4
Rustangs don't have an power antenna. Check the mast make sure it's screwed into the base all the way. Also check the underside of base of the antenna itself. It may be corroded. If that's the case, it should be replaced.
Posted Feb 12, 2008 · 01:04 UTC#5
it was never bad with my factory radio it got really bad when i installed the avic d3
Posted Feb 12, 2008 · 01:13 UTC#6
It's a ford thing. The stock radio isn't as sensitive to a corroded connection as an aftermarket deck is. If I had a nickel for everytime I was told "but it was fine with my stock radio" I'd be a millionaire.
Posted Feb 12, 2008 · 07:43 UTC#7
so what else can i do does anyone sell and antenna amp or what can i dp this sucks
Posted Feb 12, 2008 · 13:43 UTC#8
Antenna amplifier? Go to Radio Shack. Less than $10.
