Have any of you heard anything regarding the ETA of the nd-bt1 adapter?
Dustin
Posted Apr 26, 2006 · 02:49 UTC#1
KBryan said:Mine works great too. The echo is noticable to the caller, but they say it isn't that bad. The clarity through the speakers is probably the best part of it.
The phone book transfer looks like its gonna be a trick to figure out. I use a Motorola E815, and after an hour and a half, I gave up. The unit says to send the data from the phone, but there isn't a way to do it that I can see. Anyone have any luck with theirs???
whtcrxghst said:I think you can only transfer one entry at a time. I sync'd up the Z1 with my razr. Then go to the Z1 phone menu and hit 'read business card.' Went into the phonebook on my phone and did each person one at a time. On my phone, I went to each phone book entry I wanted in the Z1, hit the menu button on the phone, and then scrolled down to 'send.' It then sends the info to the Z1 through bluetooth.
KBryan said:My phone is an E815 Motorola. When you say "hit menu" do you mean go to the contacts in your phone book? Also, when you say "scroll down to send", mine just has a send button. Maybe I'm missing something.
If I go to my contacts and highlight one and hit send it calls the person since the bluetooth is disconnected at that point. At least it says its disconnecting so it can copy the phone book. Maybe I'm just having a bad week, but I can seem to get it to work.
Any ideas???
whtcrxghst said:I'm not familiar with your phone so I can't be of much help. But lets say you pull up your phonebook in the phone you have a list (Alex, Alice, etc.) If I go down to Alice and hit view, it is displaying all the info for her. If I hit the middle button right below my screen (the logo is four horizontal dashes and the first one is longer than the other three), it brings up what is called phonebook menu. It then says all the options (new, edit, delete, send message, categories, hide id, show id, add digits, attach number, copy, phone capacity, sim capacity, talk then fax, setup, copy all text, and finally SEND.) Send is what you want after you have hit read business card on your Z1.
Any ideas???
Anonymous said:I appreciate the info.....but I have no "send" in my menu. No hide ID or show ID either.
Any ideas???
NYRngrs24 said:if you have Verizon, you *may* have issues, I know Verizon disable alot of feature of blue tooth on my phone. V710. I dont have the Z1, but Ive tried other blue tooth things, for example communicating with my computer, Ill i can get blue tooth to do is headset, and internet. you can hack it to enable everything, but tis a process
