Well I finally got a new phone from Verizon. It is the LG VX 8350. Yea I know it has been out awhile but I wanted something that would connect easily to my CD-BTB200 and D3. After reading all the instructions several times over I finally got it to work and it works GREAT! Had to transfer my contacts list one at a time was the only bummer. Auto connects, hands free, voice calling and everything else works fantastically
The Instructions for the CD-BTB200 on page 34 state that the unit must hook to a vehicle with ACC power. On the very next page it states that the yellow wire (power wire) needs to be hooked to a constant 12volt source. A little confusing. I found out the answer the hard way because if it is hooked to ACC power you loose everthing in the memory when you turn the key off. So it does in fact have to be hooked to a constant 12 volts.
