Three problems here.
1. The microphone does not work. I've verified that it is plugged into the right jack on the back of the unit and is snug. If I plug it into my cell phone it works. Interestingly enough if I plug a hands free kit into the back of the Z1, the mic on that works. No explanation for that. Maybe is has a pinch in the cable and works sometimes depending on how the cable is bent.
2. My radio signal sucks. I assume this is because they didn't connect the blue wire from the Z1 into the antenna power booster (antenna is embedded in rear window)? Where is this wire.?
3. The VSS wire is also not connected to anything. What do I hook this up to?
I'd appreciate any help I can get. Pics would be awesome if possible. Thanks!
Posted Aug 09, 2006 · 02:31 UTC#1
