I have an AVIC-D3, and when I accelerate I get a alternator whine and when the car is dead silent you can hear crackling sounds coming out of the speakers when the vehicle is on. I running two PDX amplifiers and a infinity kappa speakers in the dash, rear, and door. I have no clue what this good be....I used the factory ground on my FJ Cruiser, could this be it? I asked a high-class stereo shop about grounding the RCAS and they said the D3's have been known to actually blow the rca-inputs or something along those lines if you do that. What would be a better ground?
My amplifiers are grounded directly to the chasis since I drilled a hole through the vehicle and bolted it. But how would I ground the D3 to the chassis? It's a very small 18 gauge wire and I don't have any holes....? I'm almost 100% sure this is due to the headunit ground, as there is NO way it can be the amplifier ground.
One more thing, the "crackling" increases big time when you turn the gains up the amplifiers up. So right now I have to keep them down and the system can't sound nearly as good as it should ![]()
