AVIC-Z3 Hard Drive Image **OFFICIAL**
By Hyperite · May 01, 2008in Hacks/Mods💬 436 posts👁️ 102,520 views
Page 4 of 18
Posted May 02, 2008 · 17:54 UTC#76
Here is the checksum of the .tib file obtained using megaupload method
99A22C6401349F93AD5A09F9E0B8A2F9
Posted May 02, 2008 · 17:57 UTC#77
are the 19 megaupload files virgin or mishmash?
"Virgin"
You sure?
Just did an MD5 on the Megaupload Z3 image:
Can anybody confirm they're getting the same checksum?
(use this if you don't already have a CRC tool. (Use unicode).
Confirmed.
Posted May 02, 2008 · 18:02 UTC#78
Is anybody NOT having the reboot w/ voice command issue?
If so, answer these questions:
-What physical model are you upgrading (Z1 or Z2 on the faceplate)
-What software are you upgrading (Z1 -> Z3 or Z2->Z3)
Posted May 02, 2008 · 18:03 UTC#79
You rebooting as well?
Posted May 02, 2008 · 18:04 UTC#80
I never tried that image, I'm just asking for the good of the forum.
Posted May 02, 2008 · 18:05 UTC#81
Damn. So that means the Megaupload image really is tainted, not just corrupt.
That's the SECOND tainted Z3 image I've downloaded now.
Hyperite, may as well take the Megaupload links down.
FTPing now. Third time's a charm?
Posted May 02, 2008 · 18:07 UTC#82
I already put a notice in the first post, but I'll wait to take them down until after i've tested tonight.
Posted May 02, 2008 · 18:14 UTC#83
Hum, if they're both supposed to be of the same thing (Virgin Z3 drive image) it could be possible to find the missing/damaged/changed files and upload a simple patch....
edit
Assuming compression is normal, the easiest way would be to image a HDD with the milti-part working Z3 image, then re-image to a single file tib, then run a patch maker (like Embryo Patch Maker) to determine the difference and create an IPS. 'Spose you could also do it at a file level by extracting both and comparing files. Anybody recommend any good file comp tools? I've used a few in the past but was never really happy with the results.
Posted May 02, 2008 · 18:17 UTC#84
So do any of the links contain a valid image?
Posted May 02, 2008 · 18:27 UTC#85
winmerge works quite well, grab it from sourceforge
Posted May 02, 2008 · 18:31 UTC#86
The FTP image just wrote successfully to my new HD. Checking it out now.
Posted May 02, 2008 · 18:41 UTC#87
ftp image worked great. i upgraded my z2 to the z3 with no problems. voice recon is working perfectly along with everything else(so far). i was able to keep my library intact also. thanks for all the people who got this image and the people who posted. this is truly a great site. thanks again
Posted May 02, 2008 · 18:53 UTC#88
almost done with redownloading part 1 will let you know how it works and voice command issue.
Posted May 02, 2008 · 19:19 UTC#89
did u dl from megaupload or ftp?
Posted May 02, 2008 · 19:25 UTC#90
what is the FIRST WORD in the post that you quoted....
Posted May 02, 2008 · 19:27 UTC#91
:roll::roll::roll:
Posted May 02, 2008 · 19:28 UTC#92
Got mine up and in. I used the FTP image. Changed the MSV to 18 gigs vs. 9 as well. I have 40 gigs free still (new 80GB Toshiba), but I heard too many things about going bigger and it blowing the image up. It booted and said "applying update" do not turn power off, it then rebooted about 30 seconds later and said "update failed". I was think "oh well, it was worth a try", then it loaded again with the same message, rebooted, then said Update Completed. Booted into the spalsh screen where I was pleasantly greeted with the 02/2008 TeleNav maps. That's all I wanted. God I pray it has my neighborhood in it. Nothing's more pathetic than hitting "go Home" and it basically shows I'm offroading for a mile :lol:
I hope it stays stable. BIG BIG Thanks to all of you who go this thing ripped.
Posted May 02, 2008 · 19:36 UTC#93
Just to clarify, but the mega and ftp images came from different sources, so the files are not interchangeable.
Posted May 02, 2008 · 19:43 UTC#94
Sources aside, they should both be of the exact same thing -- a virgin Z3, right? -- and therefore should be interchangeable. ... Problem is, there's a problem, and I'm curious what it is.
Posted May 02, 2008 · 19:44 UTC#95
Congrats!
so... does it?
Posted May 02, 2008 · 19:46 UTC#96
i downloaded the mega upload septicdeath version and copied it to my HDD np.
Posted May 02, 2008 · 19:49 UTC#97
Posted May 02, 2008 · 19:50 UTC#98
I D/L the image from megapath and i have a Z1 that was upgraded last year to Z2 and now Z3 with this image and I can confirm that when hitting the voice command button my unit reboots. :(
I am currently D/L the image from the FTP and will try with that next.
Posted May 02, 2008 · 19:52 UTC#99
Z1 on the faceplate
MegaUpload image
Z1 = good
Z1 -> Z2 = good (took back to Z1 for sake of upgrade)
Z1 -> Z3 = bad (brought back to Z1)
Z1 (good) -> Z2 (good) -> Z3 = bad
Posted May 02, 2008 · 19:53 UTC#100
i have a Z2 upgrading to z3 i have not tried the Z3 image in my Z2 yet but the megaupload image i downloaded was successfully copied to my MK4025GAS HDD but i need to remove the security before putting it in my drive first.
will let you know if i get the rebooting issue or not.
Page 4 of 18
