Don't you just hate it ...
By BigFloppy · May 02, 2008in Hacks/Mods💬 33 posts👁️ 5,918 views
Page 1 of 2
Posted May 02, 2008 · 04:21 UTC#1
Looks like I've got a BIG problem with my Z1
Would love to have the Z3 image BUT can't use voice commands (and I use them a lot...) because every time I go for the voice command button, it reboots on me
I CAN ALSO CONFIRM (from my standpoint) that it doesn't matter where the image comes from, both suppliers images off eBay exhibit the same issues
Oh well, back to original standard for me
FYI: Build date on my Z1 is Apr 2006
I just grabbed the box, it felt a little heavy so I looked inside and found a 110V converter I thought I'd lost a while ago :D
Posted May 02, 2008 · 04:57 UTC#2
wow :shock:
that sucks
Posted May 02, 2008 · 11:23 UTC#3
Is this a confirmed issue with all z1 owners? :(
Posted May 02, 2008 · 12:00 UTC#4
Certainly for me, I do have one of the "original" Z1's (I still have the original box as well) Looks like eBay is gonna be my friend..
Pity the poor person that gets it though!
Posted May 02, 2008 · 12:42 UTC#5
does anyone with a z2 have this problem? i will be doing mine after i have all the files. i guess i will update when i am finished
Posted May 02, 2008 · 13:35 UTC#6
BIG FLOPPY.......... this looks like an opportunity, not a problem... lets fix it :idea: ...........
Posted May 02, 2008 · 13:38 UTC#7
Believe it or not, I've actually been looking forward to getting rid of the Z1 and moving to a D3... this way I can dump the Z1 and get a D3 for basically no money out o pocket... remember, the "mishmash" that was talked about in other threads, that actually works in my Z1 BUT I'm wary at this stage just in case anything elaw is seriously wrong with my hardware... the Z2 upgrade works perfectly well
Posted May 02, 2008 · 14:10 UTC#8
well your not alone my friend just installed the Z3 image from megaupload and same thing whenever I press VC it reboots as well on my Z2.
Posted May 02, 2008 · 14:10 UTC#9
My Z1 upgraded to Z2 upgraded to Z3 does not have any problem with voice commands or rebooting... Just FYI...
Posted May 02, 2008 · 14:43 UTC#10
Did you use the megaupload RAR files?
Posted May 02, 2008 · 14:45 UTC#11
No. I used the virgin image from FTP. The first FTP file is corrupt, but will be replaced shortly.
Posted May 02, 2008 · 14:45 UTC#12
i wonder if it is a problem with the mega upload image then. i tried doing a full reset and I also was in the service menu system on it that you get to by hitting reset while holding eject. then you get the message on the screen and press plist up, up, down, down then the T button. I was looking through the version information and i saw some things were still 2.0 and not 3.0 on everything also I was looking through the error logs and noticed there were tons of errors related to the hard drive. I am wondering if it is because either A. it is not the original drive that belongs in there or B. it is a drive that I disabled security on so it cannot be locked.
Garrettoomey your image is the one on the FTP server correct? Is that known to be good and working that I can try out to see if that fixes the issues.
Posted May 02, 2008 · 14:48 UTC#13
Information incase it can prove to be useful and dont have to search for it:
Pioneer AVIC-Z2
Hard Reset Unit:
When Pioneer boot logo appears on screen during startup press and hold the MAP BUTTON. Keep holding it until the reset menu appears and choose the option desired.
Service Menu:
Fold the screen down by hitting the eject button on the front. Make sure there is no disc in the unit. Once the screen is down press and hold the inner EJECT BUTTON while taking a small pin and pressing the small RESET BUTTON on the front panel. You will see "Push Reset button or Restart Engine" at this time release the EJECT BUTTON.
Enter the following password sequence:
P. List Up
P. List Up
P. List Down
P. List Down
T
Service Menu Will Appear, Hit the outter face close eject button and you will be in service menu.
Use arrows to move between options and pages, use AV for back button, and use T for enter button. To exit push reset button or turn car on and off.
I ALSO NOTICED: that when you hard reset with the mega upload image and do the hard reset by choosing clear all data. it freezes and just chills there until the unit is powered off and on again. I think its the mega upload image that is bad.
Posted May 02, 2008 · 14:58 UTC#14
the one thing i will say though is that the 60GB 7200 RPM laptop hard drive that i stole from my dell laptop is fast as hell. The pioneer boots up in seconds.
Posted May 02, 2008 · 15:06 UTC#15
7200 RPM :shock:
did you road test that HD ?
with out any problems ?
Posted May 02, 2008 · 15:07 UTC#16
Dan,
Whats the manufacture date of your Z1 ?
Posted May 02, 2008 · 15:12 UTC#17
i will let you know lol i have a 20 minute drive to work in about an hour or so. I have a 30GB 4200RPM drive layin around just incase. I looked up the specs of the 7200 drive and it has the same 200G operating shock allowance as our toshiba drives that came in the unit so i think it will be ok.
Posted May 02, 2008 · 15:14 UTC#18
it is a Z2 and i believe that it was july or sept somewhere in there 07 i dont have the box anymore. i typed it on my reciept notes along with the serial number when i worked at circuit city because that is when i bought it and i am not there anymore but i wanted the info on file incase it was ever stolen out of my car. i could have them look it up for me.
Posted May 02, 2008 · 15:15 UTC#19
i think its the 7200 RPM avic cant handle that speed and will lock up on you
manny ppl have try to use that HD
no luck :(
Posted May 02, 2008 · 15:30 UTC#20
Not sure, lol.
It is a Hitachi Travelstar 7K60 Model: HTS726060M9AT00
60GB 7200RPM 2.5" Drive
Posted May 02, 2008 · 15:32 UTC#21
I've got $5 that says that Hitachi drive will freeze on you... No one has found any non Toshiba drive to work in the Z...
But please let us know. Would love to find another drive that would work.
Posted May 02, 2008 · 15:56 UTC#22
Toshiba drives rock!
Posted May 02, 2008 · 16:08 UTC#23
Actually toshiba sucks, any computer problem I ever had was due to crappy toshiba products.
Posted May 02, 2008 · 16:11 UTC#24
i dont wanna sound like a retard
by my voice command button is missing :oops:
i have Z2 june production
where is the button located ?
i know i saw it before i just never used it
Posted May 02, 2008 · 16:15 UTC#25
Your mic is not plugged in or not plugged in completely.
Page 1 of 2
