VSS location on 07' Honda Fit
By moondog · May 20, 2008in Problems/Troubleshooting💬 6 posts👁️ 1,972 views
Posted May 20, 2008 · 21:17 UTC#1
I've tried searching but can't find any info on my Honda Fit VSS wire location. Does anyone know? Whats the Reverse signal for and do I have to hook it up as well? thanks!
Posted May 20, 2008 · 23:39 UTC#2
See if this helps you find your VSS wire. http://avic411.com/forum/viewtopic.php? ... hlight=vss
The reverse signal wire is if you plan on hooking up a rear camera to your unit, it supplies the signal to turn the camera on when you put it in reverse. If you're not hooking up a camera, you don't need to connect it.
Posted May 21, 2008 · 04:22 UTC#3
Thanks for the info on the reverse signal. Unfortunatly the VSS database doesn't include anything on the Honda Fit. My stock radio has a speed volume sensor so I think I can patch into the stock harness somewhere. Anyone know which wire??
Posted May 21, 2008 · 15:36 UTC#5
Awesome!! Thanks for the help.
Posted May 22, 2008 · 14:54 UTC#6
Glad I could help. Be sure to let us know how things turn out.
