How To: Find your Vehicle's VSS Wire.
By JasonH · Oct 24, 2005in Vehicle Specific Wiring💬 346 posts👁️ 199,818 views
Page 1 of 14
Posted Oct 24, 2005 · 23:00 UTC#1
Simply enter your Vehicle Year/Make/Model here, and it will tell you where the VSS Wire is.
http://www.rostra.com/techsupport-main.asp
Posted Mar 01, 2006 · 15:28 UTC#2
Whats a VSS wire? I'm getting a lincoln zephry and avic z1, and I don't see my car listed. Thanks and God Bless.
Posted Apr 28, 2006 · 22:53 UTC#3
Ok I have a 2004 chrysler crossfire, should be the same as a 2003 mb slk 320.
Any ideas?
Posted Apr 28, 2006 · 23:41 UTC#4
Any ideas?
Did the stock radio have the "gets louder as you go faster thing"?
If it does, the VSS will be wired into the radio allready and will be included in your vehicles wire harness.
Posted Apr 29, 2006 · 03:52 UTC#5
Mine did not have that feature but I will look to see if there are any extra wires there. Thanks.
I'll post if I find any info so others will know too
Posted May 06, 2006 · 03:32 UTC#6
To add my .02 the vss wire is not under normal circumstances pinned in an aftermarket harness. The best bet as far as testing for the vss wire is to grab a meter set it to ac voltage. Ground the negative probe and probe your suspect wire. put the car in drive and watch the reading. It should fluctuate with vehicle speed.
Posted May 14, 2006 · 16:15 UTC#7
i just noticed my VSS isn't connected on my 'dealer/professionally' installed N1 in a 2005 toyota sequoia, anyone know where it is ? I checked the listed sites and couldn't find it.
Posted May 15, 2006 · 20:24 UTC#8
VW's aren't listed on that site, but I found the info elsewhere, the VSS wire is located in the 32 pin connector on the back of the gauge cluster. Its pin #3, on my car (2005 GTI) its blue with white tracer, but other pictures I've seen its white with a blue tracer. Make sure not to have the key in the ignition while the connector is removed or it will cause an airbag fault requiring a trip to the dealer to reset (so I've read). Got the info from www.vwnavi.com in case other VW folks need other info (not sure how common the color/location is across other models).
Admin Edit: Fixed the Link.
Posted May 20, 2006 · 05:42 UTC#9
HI to all of you if somebody know where to find vss for lexus gs 300 2002 i was looking diffrent sites but no luck
thank you very much
Posted May 26, 2006 · 15:09 UTC#10
Any ideas?
Is that the case for all cars with that feature? My Yukon had that. Is there way to test?
Thanks, that would be great if this worked.
-Scott
Posted May 27, 2006 · 04:53 UTC#11
Any ideas?
-Scott
Depends on the year of the yukon. Though if you can fit the d1/d2/z1 in the truck, then no you can't get it at the radio harness.
Posted May 31, 2006 · 16:49 UTC#12
Any idea where to find this wire on a 2002 Porsche Boxster S? The linked site doesn't even have Porsche listed.
Posted Jun 20, 2006 · 20:22 UTC#13
what is the purpose of this wire and the navigation? I am installing a avic 80dvd. Any idea if I will need to find the wire? Thanks, Greg
Posted Jul 15, 2006 · 18:37 UTC#14
Greg-
The Z1 (and almost all other permanent nav systems) use what is referred to as dead-reckoning to provide a more precise indication of where you are located. Contrary to popular belief, the system does not continuously track the satellites it can see, rather it gets periodic updates to as to where it is located on the Earth's surface. By tying into the vehicles speed, the nav system can use the previous known location and heading from the satellite to determine how far the vehicle has travelled.
Dead-reckoning combined with the internal gyroscope also makes the system much more accurate when it can't get a good fix on location from the satellites (like in a tunnel, or downtown in a large city).
Posted Jul 16, 2006 · 01:46 UTC#15
Very Good! And I have found the vss and connected the unit, avic 80 seems like a fine unit. Thanks for the reply!!
Posted Aug 26, 2006 · 20:15 UTC#16
My car is not there... I have a Mercedes-Benz C230k 2002... Anything I need to know b4 the installation?
Posted Oct 27, 2006 · 14:21 UTC#17
I went to the site but could not for the life of me find any links for my VSS location. After entering my vehicle year/make/model, I was directed to a page that contained products for my car (rear camera system, etc.). But nothing on VSS. Can you be more specific on where to get this info on the site? Thanks.
Posted Oct 27, 2006 · 18:42 UTC#18
tell us the year/make/model!
Posted Oct 27, 2006 · 19:38 UTC#19
2006 Hyundai Azera Limited
Posted Oct 28, 2006 · 00:42 UTC#20
2006 Hyundai Azera
Speed Sense yellow data link connector, pin 6
Notes: The data link connector is under the driver side dash.
Also found at the BCM, 16 pin plug, pin 10.
Also found at the amplifier, if equipped.
Reverse Light white + back of fuse box, 9 pin plug, pin 5
Merry Xmas.
Posted Oct 28, 2006 · 02:44 UTC#21
2006 Hyundai Azera
Merry Xmas.
Thanks for the info. I'll report back with my progress.
P.S. What does "BCM" stand for? Where is it?
Posted Oct 29, 2006 · 23:24 UTC#22
Its the body control module. As for where it is I don't have the info infront of me right now so I couldn't say. You're better off though picking it up at the data link connector though. Easier to get at.
Posted Oct 30, 2006 · 01:19 UTC#23
Yes, thanks - I found the Data Link Connector under the dash. Question: do you think it's OK to simply plug a male connector into the pin 6 to get access to it (as opposed to splicing the wire)??
ALSO: can you tell me the easiest spot (under the dash??) to tap into the reverse signal (I'm not looking forward to snaking a cable to rear taillight!!)?
Posted Oct 30, 2006 · 01:28 UTC#24
I wouldn't just plug in, you should splice it, better connection and should someone need to plug in a scantool into the connector you don't have to worry about them remembering to plug your wire back in.
I can only go off the info that I gave you since I've not done a nav system in that car. Your other option should you not be able to find the reverse wire where I posted would be to look for the same colored wire in the bundle of wires that runs to the back of the car in the drivers kickpanel under the carpet.
Posted Oct 30, 2006 · 01:35 UTC#25
Thanks for getting back so quickly. I looked back to the post you made on the reverse; which fuse box are you referring to? The one under the driver's-side dash? Thanks.
Page 1 of 14
