How To: Find your Vehicle's VSS Wire.
By JasonH · Oct 24, 2005in Vehicle Specific Wiring💬 346 posts👁️ 199,818 views
Page 3 of 14
Posted Jan 24, 2007 · 22:26 UTC#51
VSS is yellow with a white stripe at the diagnostic plug under the dash, and reverse is red with a blue stripe in the driver's kick panel.
Posted Jan 24, 2007 · 22:32 UTC#52
thanks...i'll look at it tonight...
Posted Jan 24, 2007 · 22:52 UTC#53
I get this for a 99 mits 3000gt
Speed Sense = white/red in data link connector which is under the driver side dash.
Posted Jan 24, 2007 · 23:05 UTC#54
okay now i'm confused.....
white/red
yellow/white
red/blue
i just need to find the pulse sensor...
Posted Jan 24, 2007 · 23:06 UTC#55
welp, it is probably a simple case of different locations for the vss look for the one that is easiest for you
Posted Jan 26, 2007 · 13:02 UTC#56
I guess every database has a different answer. I'm using the Installogy Access Client from Autopage.
Posted Feb 04, 2007 · 17:59 UTC#57
where is it on a 2005 Ford F-250 crew cab diesel 4x4?
Posted Feb 04, 2007 · 22:15 UTC#58
If you have the 6 disc changer. It's gray/black at the radio harness. If not it's the same color at the abs module under the hood.
merry xmas
Posted Feb 06, 2007 · 00:39 UTC#59
ive read in other posts that there is no vss wire on my car, ive located the reverse wire, but to no avail on a vss. any help would be great. someone told me i need to purchase a spreed pulse generator. any info would be great. 2006 ford 500 ltd. thanks for the help
Posted Feb 06, 2007 · 04:23 UTC#60
There's pretty much always a vss wire in newer cars. It's just a maatter of what lengths you're willing to go to get it. Most common places are, transmission, abs module, wheel speed sensor, and the ecu. By the way both databases I have access to say to use a wheel speed sensor. No color info though.
Posted Feb 06, 2007 · 05:25 UTC#61
so what do you recommend, i would really like to get this vss wire connected. my nav being off can be very irritating sometimes. let me know what you think, and im willing to do just about anything for something to work. thanks again
Posted Feb 06, 2007 · 05:37 UTC#62
I'd say find a wheel speed sensor then. You have a 50/50 shot of hitting the right wire at that point. Unless someone else here has access to a database that gives a better location.
Posted Feb 06, 2007 · 06:00 UTC#63
I'm looking for the Speed Wire on a Toyota Matrix '07..
The website does not mention anything about the '07.. I checked the '04 Model then and there's some info.. I just don't know which one is the right one (possibly the same on the 07..)
I see this:
VSS Wire: LOCATION 2- 4 CONNECTOR ECM- 2ND CONNECTOR LEFT TO RIGHT
VSS Wire Color: VIOLET/WHITE
VSS Pulse: 4000
VSS Tach Wire: LOCATION 2- (E6) 31 PIN CONNECTOR OF ECM POSITION 5
Tach Signal Wire Color: BLACK
Now which Wire is the RIGHT ONE to connect the Z3' Speed Wire?? VSS Tach or just VSS?
Now I do see this on the bottom:
VEHICLE NOTES: BELOW GLOVEBOX 4 CONNECTOR ECM
This is the location of where I have to run the wire to, correct? My other car was all the way in the engine that's why that strucks me odd..
Thanks in advance!
Posted Feb 06, 2007 · 06:06 UTC#64
z3? but it would be vss wire, not tach.
Posted Feb 06, 2007 · 07:57 UTC#66
Thanks cntryl! I got your answer on the other topic!
I'm sorry, I mean AVIC-Z1. Not sure why I typed Z3 back there.. I was mixing the N3 with the Z1 probably. :)
Posted Feb 08, 2007 · 22:11 UTC#67
I have a 99 Toyota Landcruiser with a AVIC-D2 that was recently installed. The installer did not hookup the VSS wire either (didn't know this til yesterday when I started telling them about minor NAV problems). Guy told me he couldn't find it. This was installed by Circuit City and you would think they would have access to this information. I knew I probably should have installed everything myself but install was it was free so I figured what the hell; let em do it. The D2 is nice but a tease in many ways. My navigation is slighty off (hoping the VSS hookup fixes this. I need to open up the dash to bypass so I'll wait until I find out where the VSS is and hook it up. The IPOD interface with this unit is also driving me nuts and others I see on here as well. I guess I should have done more research before buying this unit but didn't really want to drop 2 grand on the Z1.... Anyone got other good alternatives for playing MP3's over the IPOD? Also, where can I get software updates from Pioneer? Seems like a software or firmware upgrade could fix this.
Posted Feb 08, 2007 · 22:38 UTC#68
Hurray for lazy circuit city installers. Take the truck back, tell them to hook it up. Here's where it is incase they argue it's not in the truck
Speed Sense purple behind the glove box
Notes: Located in a 28 pin connector at the ECM behind the glove box.
As for updates, the d2 has the most current updates already, nothing availible yet to change anything. The new map set should be out in a month or so, that'll take care of the maps. Any other changes at this point are purely speculation. The ipod thing, I'd check the d1/2 forum there are several topics on alternatives to the crappy pioneer interface.
Posted Feb 09, 2007 · 01:42 UTC#69
cntrylvr79,
Thanks man. You seem to know your stuff well. Too bad you don't work at the circuit city by me in VA. This will be the 5th time I've had to take it back... Maybe 6. All my reading seems to indicate that I should just shell out the extra $$$ and get the Z1 or try another brand. Maybe I will see if they will let me upgrade to the Z1 and have the other unit removed...
Oh yeah... What else will hooking up the speed sense wire help or do for the unit??? Will it only help my NAV unit be more accurate; like it doesn't seem to know my home address... but it knows the street name sometimes but sometimes it thinks i'm a street over...
jason
Posted Feb 09, 2007 · 04:16 UTC#70
Doubt it's going to fix those issuses. That's an imperfection in the software that's saying you're on a different street than you are really on. As far as the home address thing goes you could try waiting for the updated map set otherwise you'd have to do what I did and modify the location for your home.
BTW I don't know what I'm doing, I'm just really good at faking it.
Posted Feb 12, 2007 · 17:26 UTC#71
Simply enter your Vehicle Year/Make/Model here, and it will tell you where the VSS Wire is.
http://www.rostra.com/techsupport-main.asp
Hi I have a chevrolet tahoe 2001 the cluster conector has two green/white wires A12 and A3 wich one is the VSS wire
Posted Feb 12, 2007 · 19:18 UTC#72
Easier option is to look at the radio harness. There should be a green/white wire there. That is your vss wire. As for the gauge cluster, couldn't tell ya which one. Best bet is to test them.
Posted Feb 22, 2007 · 15:18 UTC#73
Howdy all, I've been a diligent poster and searched to no avail for my vehicle. I need to know where/wire color is for VSS and ILL for a 2007 Ford Freestyle with the Audiophile system (In-dash 6-disc player with speed sensing volume control)
Thanks for all the help! Y'all are mighty helpful! :)
Posted Feb 22, 2007 · 15:35 UTC#74
All my info says go to a wheel speed sensor for vss. So my guess is the vss info may be sent to the radio through data. Sorry bro. At least at a wheel speed sensor you only have 2 choices. 50/50 chance you get the right wire on the first shot.
Posted Feb 22, 2007 · 17:16 UTC#75
Thanks, ok don' t do all the work for me, if you want I can help you.
For the Chevy Tahoe Z71 2001
In the green/white wire of the radio harness, and the green/white wire of the cluster harnees ( pos A3 ) you can find the speed signal ( VSS ), and for the reverse signal the geen wire off the conector of the center instrument panel utility block located under the instrument panel on the left side of the steering column.
Hope it helps
Page 3 of 14
